Morph transformation effect
Paul Fisherman
on Mar 12, 2016 at 2:03:25 pm
In the second and third Matrix, Agent Smith jabs his hand into a victim and a black gooey substance starts to spread around them and eventually morph them into one of Agent Smith's kind. I'm going to assume that was done through 3D. How would I go about achieving this liquid effect-morph style thing?
Here's what I'm talking about:
"It's all around us Neo, temporary constructs of time....."
Tudor "Ted" Jelescu
Re: Morph transformation effect
on Mar 12, 2016 at 5:03:00 pm
In AE without using C4D or another 3d program to render the liquid mercury like transformation, you can use something like FreeForm Pro from Mettle to generate a similar surface. You can build a animated displacement map that approximates the shape of your subject to displace the surface in 3d space, then use the noise generator to animate the surface and create the watery/mercury flowing effect. A Reflection map and a animated texture will complete the process.
Below is an example of water done with FF Pro that can give you an idea of what the plugin can do if you're not already familiar with it.
Tudor "Ted" Jelescu
Senior VFX Artist
Paul Fisherman
on Mar 13, 2016 at 12:23:49 am
Oh man, Im lost. Could be you make a tutorial on that? Or point me to one?
Tudor "Ted" Jelescu
on Mar 13, 2016 at 11:45:24 am
Here's an older tutorial on displacement. It's on a still image but principles are the same for video:
https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
Here's a link to the tutorials on the Mettle site:
http://www.mettle.com/tutorials-freeform-pro/
You can use more techniques from there.
Tudor "Ted" Jelescu
Senior VFX Artist
