Character Offset Woes
Charles Ferran
on Mar 11, 2016 at 3:54:05 am
Hello CC!
I'm having a frustrating thing happening to me that I'm sure is a checkbox somewhere I'm missing.
When I put a character offset on a text layer and then change offset, it changes, but it changes every character to the same character. I'm doing numbers only, (clock face) and they all change, but all zeroes turns to all ones, etc. I want them to change separately, (0000 becomes 3289 or 5639 instead of 1111, 4444, etc)
What am I missing here?
Charles Ferran
845-699-5270
http://www.charlesferran.com
"Far better is to dare mighty things, to win glorious triumphs, even though checkered by failure than to rank with the poor spirits who neither enjoy much, nor suffer much because they live in a gray twilight that knows no victory or defeat."
Dave LaRonde
Re: Character Offset Woes
on Mar 11, 2016 at 6:27:13 pm
You'd need to select individual characters to do this, instead of the entire layer.
I take it AE's Numbers effect doesn't cut it for your purposes.
Dave LaRonde
Promotion Producer
Charles Ferran
on Mar 11, 2016 at 8:54:43 pm
Hi Dave! My favorite person on CC ;)
Is it because they're numbers? I'm seeing videos of people using this effect and having all the characters generate individually. What am I missing?
I think for now I can make 'numbers' work though, thanks Dave!
Charles Ferran
845-699-5270
Kevin Camp
on Mar 11, 2016 at 10:41:19 pm
you can set the character offset value of the animator (to say 6) and then animate the 'offset' value of the range selector (not the 'character offset' value), and if the 'based on' value is left at the default 'characters', then each number will sequentially count from 0 to 6... however that's not exactly how a clock would count...
--- edit ----
actually if the offset value was 6, then animating the offset would cause each digit to count from 6 to 0....
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
