How to align points and tangents on 2 different masks?
Jeff Cottle
on Mar 9, 2016 at 10:20:13 pm
Hello,
i hoped anyone could please show,.
1) how to align points and tangents on two different masks?
Any help appreciated,
J
Dave LaRonde
Re: How to align points and tangents on 2 different masks?
on Mar 9, 2016 at 10:50:48 pm
I'm darned sure we could if we had a better idea what you actually meant. Can you describe what you want to do in more detail?
Dave LaRonde
Promotion Producer
Jeff Cottle
on Mar 10, 2016 at 11:16:16 pm
..sure Dave, heres a near exact description:
imagine mountains1 at the horizon, and another line of mountains2 just infront of it closer to the viewer.
Both mountains have masks along their tops and bases, and what i need to do is align the mountainTop1 points and tangents on mask1, with the mountainTop2 mask2 points and tangents.(screenshot if needed)
ie: need to align a mask point position&tangent with that of a different mask point, one at a time or all at once,
Thanks again,
J
Walter Soyka
on Mar 11, 2016 at 3:50:23 pm
If you are repeating masks across several layers, you might find it easier to use track mattes instead:
https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.htm...
Walter Soyka
jay mueller
on Mar 10, 2016 at 3:08:41 pm
How about using guides? Place guide(s) to point/tangent and then set additional mask to those guides.
Jeff Cottle
on Mar 10, 2016 at 11:21:27 pm
..will give it a try Jay, never used Guides so will look 'em up 1st,
thx
Dave LaRonde
on Mar 11, 2016 at 1:08:15 am
It seems from your description you need to position one masked layer is a desired position with another layer. I'd say just use the position property. If it takes you more than 5 minutes to get just what you want, there's something wrong.
Dave LaRonde
Promotion Producer
