Change ellipse shape layer to rectangle
Emily Davies
on Mar 8, 2016 at 5:05:52 pm
I have created an after effects composition which is basically shapes and text moving/zooming in and out. However, I now need to change all the ellipse shapes to rectangles - they move around in a path and change size, position etc as well as holding text. How do I simply change the ellipse shape layer to a rectangle without removing any of the properties? Thank you
John Cuevas
Re: Change ellipse shape layer to rectangle
on Mar 8, 2016 at 5:41:38 pm
Make the rectangle shape you need, twirl open the contents and copy the rectangle path and paste it into the ellipse contents. Move it to the top of the stack then delete ellipse path.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
