Enlarge composition with particular layers is not possible?
Tom Raas
on Mar 8, 2016 at 2:07:04 pm
I have a composition with 10 Illustrator files which are dissolved by Particular. Now, I want to enlarge this composition and I tried the following:
- Using the script "scale composition.jsx" --> Everything scaled correctly except my particular layers, these layers got extra large.
- Open my comp in a new comp and scale it --> the comp enlarges but does not keep the vector and instead just enlarges the pixels.
Can anybody please help me, I do not want to build it all form scratch. Thanks in advance!!!
Tom
Tudor "Ted" Jelescu
Re: Enlarge composition with particular layers is not possible?
on Mar 9, 2016 at 1:50:35 pm
I may be mistaken, but even if you copy the Particular settings, create a new layer the size of your enlarged comp and apply the settings to it you may still have to play around with the position of the generator and size of particles.
Tudor "Ted" Jelescu
Senior VFX Artist
