Masks in after effects leaving weird grey outlines
Arindam Sen
on Mar 6, 2016 at 10:35:12 am
I added and subtracted the same mask from the same image but its leaving a weird grey outline.
Here is an example of the same:
There is no feather on the mask. Is there any particular setting that needs to be checked because i don't remember encountering this before.
Chris Evans
Re: Masks in after effects leaving weird grey outlines
on Mar 7, 2016 at 5:23:02 pm
It's the result of aliasing. You'll just have to change the mask expansion on one of the masks by a pixel or two.
Arindam Sen
on Mar 8, 2016 at 3:42:04 am
That did the trick. Thanks so much Chris!
