Rotobrush Issues
Jenn Stine
Rotobrush Issues
on Mar 6, 2016 at 1:17:37 am
Please reply ASAP.
So my rotobrush does not seem to be working. I am using the correct controls. I drag my mouse around my subject and it does absolutely nothing! I have no idea what is going on. I do see a sign that says "Frame rate mismatch. For best Roto Brush & Refine Edge results, set the composition to 29.97 fps to match the layer source." Does that have anything to do with it? Thanks
Dave LaRonde
Re: otobrush Issues
on Mar 6, 2016 at 9:22:48 pm
It appears very straightforward. It's a frame rate mismatch. To get an accurate diagnosis, you'll have to tell just what you're doing -- with great detail given to frame rates.
For example: you shot 24P BUT didn't remove the 3:2 pulldown. It's a common error for those who don't fully understand how some cameras work.
Dave LaRonde
Promotion Producer
