Automation After Effects
peter brelan
on Mar 4, 2016 at 1:10:40 pm
Good morning,
i'd like to create weather clips every 4 hours
I'd like to change automatically icons and temperatures with XML or other data. Do you know if it's possible ?
Regards
Pierre
Tudor "Ted" Jelescu
Re: Automation After Effects
on Mar 4, 2016 at 1:20:04 pm
I know there is a script (aescripts.com) that can enable AE touse excel data:
http://aescripts.com/compsfromspreadsheet/
AND
a XML to EXCEL conversion tool (there are other options as well)
http://www.altova.com/download-excel-mapper.html?gclid=CMb0v66Pp8sCFcUucgod...
Maybe you can make use of these combined?
Tudor "Ted" Jelescu
Senior VFX Artist
Walter Soyka
on Mar 4, 2016 at 2:55:06 pm
You can also build an automation pipeline around After Effects XML project files [link].
Walter Soyka
peter brelan
on Apr 3, 2016 at 10:18:20 pm
WTHank you
what do you mean by a pipeline around after effects?
Walter Soyka
on Apr 4, 2016 at 8:25:04 pm
[peter brelan] "what do you mean by a pipeline around after effects?"
I just meant that you could build a repeatable process around this automation.
Pipeline: a set of data processing elements connected in series, where the output of one element is the input of the next one. (Wikipedia [link])
Walter Soyka
