Trapcode Particular for strokes - particles showing from the beginning
Sumit Sarkar
on Mar 4, 2016 at 12:51:46 pm
Hi there. hope someone can help, couldn't find the answer online..
I'm using trapcode particulars to create strokes. it was going fine but now 80 odd strokes in, the particles are showing right from the start. (i.e. after frame 1 all the particles are showing at the start points :/
any suggestions as to what I've done wrong?
many thanks in advance
John Cuevas
Re: Trapcode Particular for strokes - particles showing from the beginning
on Mar 4, 2016 at 3:24:41 pm
Off the top of my head, are you using one instance of particular with multiple emitters, or multiple instances. Also, can you post a screen grab with your particular settings and timeline visible?
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
