About links from Slider Control to Slider Control on other comps
Fabio Santos
on Mar 3, 2016 at 8:59:39 pm
Hi! I have a doubt.
1) I have a comp front_mouths inside other comp (heads) > front_man > man_positions > man. - Look at the img 01.jpg.
2) Inside front_head I have a Slider control (Slider_mouths) and the front_mouths linked to this Slider control. - Look at the img 01.jpg.
3) The front_head's Slider_mouths linked to Slider_mouths from man comp. - Look at the img 02.jpg.
4) The man's Slider_mouths moves only in first frame. From second frame to forward don't change de mouths. - Look at the img 02.jpg.
How can I fix it?
Image 01
Image 02
Walter Soyka
Re: About links from Slider Control to Slider Control on other comps
on Mar 4, 2016 at 2:32:43 pm
Can you post your AEP file?
Walter Soyka
Fabio Santos
on Mar 4, 2016 at 2:48:27 pm
Hi Walter!
You can do the download in this URL: http://we.tl/paXt3opbTQ
The file is in Afx CC 2015 and you need to use de Duik plugin. http://duduf.net/index.php/products/after-effects/duik/download/
Thanks you
Walter Soyka
on Mar 4, 2016 at 4:38:47 pm
I think your issue comes from the fact that your comps do not all share common time. Frame 1 in "man" does not necessarily might correspond with frame 6 in "man_positions," which might correspond with frame 10 in "3Q_rgt_front_man," etc.
It might be better to keep a common timebase for all your comps and precomps and use the sliders to control the opacity of different character rig layers, only revealing the precomps/layers you need according to the slider values.
Walter Soyka
Fabio Santos
on Mar 7, 2016 at 6:31:27 pm
Hi Walter.
I'll try to do about what you explained
Thanks to your help!
Fabio Santos
on Mar 21, 2016 at 8:29:48 pm
Hi Walter!
I did like you said and worked well! The cod used it's the bellow:
var=comp(“mainComp”).layer(“layerControl”).effect(“Slider Control”)(“Slider");
if(var==0){
100;
}else{
0;
