Multiple objects following a path.
Russel Tait
on Mar 3, 2016 at 10:00:54 am
Im sure Im missing something very obvious.
Im trying to animate a line of 24 circles.
The idea is they follow a path around the screen in a trail and then form a ring in the centre around a logo.
I can get one to follow the path, but the only way I can get the others to follow is to give each its own slightly adjusted path.
Is there a way so that Im only using one path?
Thanks in advance.
Dave LaRonde
Re: Multiple objects following a path.
on Mar 3, 2016 at 3:31:23 pm
Sure - use duplicated layers. Offset their inpoints on the timeline. Modify the ending position keyframes if necessary.
That's one way to do it.
Dave LaRonde
Promotion Producer
Kalle Kannisto
on Mar 3, 2016 at 7:44:58 pm
Check out Ourobouros (free plug-in):
http://www.sandervandijk.tv/blog/ouroboros
