After Effects Renders to Premiere with Red frames when replacing file
jamie mcgee
on Mar 1, 2016 at 8:30:21 pm
Am having a few issues between After effects and Premiere, and not sure where the issue sits.
I am on a new Mac Pro, 6 core, 64GB Ram Firepro D700
AE/PREMIERE 2015.2
I have some 1080 25p Compositions in AE which I render out to PRORES
Import them into Premiere 1080 25p seq
Export to various H264/ProRes
If I open AE and Premiere simultaneously, and have a PREM SEQ with a Rendered AE Composition file open in Premiere and then switch to AE, and make an adjustment on the Comp and RE-Render the composition to overwrite the Exported file, It updates in Premiere, but when I play the file in Premiere now it will often have Red frames in it.
Red frames are also there when I export.
If I close Premiere and empty Cache, it corrects itself.
Or if I Close Premiere before I do the Render from AE the Red frames dont appear.
I dont remember this being an issue prior to 2015, also this week it seems to be especially bad. Occasionally the red frames are not present on the Premiere timeline, but are there on export.
Posted in Premiere Forum as well.
Any advice would be much appreciated.
jm
Dave LaRonde
Re: After Effects Renders to Premiere with Red frames when replacing file
on Mar 1, 2016 at 11:23:50 pm
The short version -- use AE CC 2015 only when necessary. If you can do the job in AE CC 2014 -- which you can get if you don't have it -- you are much better off doing so.
AE CC 2015 is just weird.
Dave LaRonde
Promotion Producer
