Deprecated Premiere-After effects copy/paste workflow issue
Jurij Magoga
on Mar 1, 2016 at 6:18:26 pm
I've been using for a while the copy/paste workflow for moving my edited clips from Premiere sequences to After Effects compositions, and found that I like it much more than Dynamic link.
After last updates though this workflow became very buggy, i.e. sometimes it paste just one clip or it keeps pasting the first copy i do, like it was not able to flush the clipboard when new clips are copied in.
Quitting and relaunching apps doesn't work.
Anyone has experienced this behaviour?
Any solution?
Thanks in advance :)
Dave LaRonde
Re: Deprecated Premiere-After effects copy/paste workflow issue
on Mar 1, 2016 at 6:55:50 pm
What was the last version that worked well for this? I'd use it.
Dave LaRonde
Promotion Producer
Michael Szalapski
on Mar 1, 2016 at 7:29:52 pm
You could also try using the File>Import Premiere Pro Project command. It's separate from the regular import command and it should bring your whole Premiere sequence with each edit on its own layer.
- The Great Szalam
Jurij Magoga
on Mar 2, 2016 at 7:29:23 am
Thank you Michael, your workaround certainly works, but I feel very handy the copy/paste thing and if it is still there it would be fine if it worked properly.
Anyone has noticed that after last updated of PPro and Ae the copy/paste stopped working properly.
I'm on osx el capitan with ae 13.7 e ppro
