Missing audio clips in importes sequence
Gary DeVaan
on Feb 29, 2016 at 5:54:41 pm
I have a voice over that I created in a Premiere sequence that consists of 3 wave files. When the sequence is imported into AE suddenly only 1 of the wave files show-up in the waveform in AE, no sound, no waveform. I've purged memory, re-loaded & re-linked clips and I can't fine a solution. The clips are 1411 kbps wave files, nothing special. They did all show/play until today, but it was always hokey when I wanted to edit in Premiere, I always had to reload reboot or purge memory before changes appeared in After Effects. any ideas would be greatly appreciated.
Chris Wright
Re: Missing audio clips in importes sequence
on Feb 29, 2016 at 10:09:19 pm
are they really PCM wav?
1. try a quick encode with handbrake to PCM wav and try importing again
2. start a new sequence in a new project, the project may have gotten corrupted. delete any old .pka files.
