How can this sort of a blur effect be achieved?
Dhruv Sharma
on Feb 29, 2016 at 11:39:50 am
The effect in question is at 1:04 in the following video.
How can I get it without using any plugins? or which plugin is used for it?
Tudor "Ted" Jelescu
Re: How can this sort of a blur effect be achieved?
on Feb 29, 2016 at 12:31:13 pm
Duplicate the layer, pull a key using Luma to get the highlights, animate a vertical directional blur and add glow. Play around with transfer modes - work at 16 or 32 bit.
Tudor "Ted" Jelescu
Senior VFX Artist
Daniel Waldron
on Feb 29, 2016 at 3:30:12 pm
Also, check out this handy tutorial from here on the COW.
Eric Santiago
on Feb 29, 2016 at 5:52:31 pm
Mask the area as well before applying any blurs.
Sometime scaling the layer help (vertical in that case).
Joseph Boutilier
on Mar 1, 2016 at 2:44:21 am
A directional blur is the simplest way to replicate that exact effect. However, it sort of simulates a type of lens flare; you might also research flares and the Video Copilot Optical Flare plugins if you're looking to create multiple effects with that aesthetic.
