Extendscript parse unicode characters into text layer
Peter Esel
on Feb 28, 2016 at 5:53:42 pm
I'm trying to write a script that parses an array of characters into subsequent keyframes of a text layer in After Effects. Everything works. Only I'd like to change the function to read unicode instead of normal text.
Here's my Code for the Script:
var textLayer = currentComp.layers.addText("test");
textLayer.name = "score";
textLayer.position.setValue([50,500]);
//Chose the txt with the array
var myFile = File.openDialog("Navigate to keyframe file.");
myFile.open("r");
var myLine = myFile.readln();
var keyValues = myLine.split(",")
var prop1 = app.project.item(1).layer(1).property("ADBE Text Properties").property("ADBE Text Document");
var arrayLength = keyValues.length;
//Keyframe Loop
app.beginUndoGroup("Keys");
for(var i=0; i<arrayLength; i++){
prop1.setValueAtTime([i]/25,keyValues[i]);
app.endUndoGroup();
And this is the String that i'm trying to parse:
\u5c07,\u63a2,\u8a0e,\u53ca,\u5176,\u4ed6
These are all unicode characters.
Thanks a lot!
Pete
