easy ease PROBLEM with Linear/ease()
Bilal Alsurri
on Feb 21, 2016 at 9:17:33 pm
Hello,
am trying to link some keys to markers using Dan Ebberts expression:
L = thisLayer;
if ((L.marker.numKeys > 1 ) && (numKeys > 3)){
sIn = key(2).time - key(1).time;
sOut = key(4).time - key(3).time;
eIn = L.marker.key(1).time;
eOut = L.marker.key(2).time;
if (time < L.marker.key(2).time)
linear(time,eIn-sIn,eIn,key(1).value,key(2).value)
else
linear(time,eOut,eOut+sOut,key(3).value,key(4).value);
}else
value;
which in my project case i changed "L" to target a layer in the parent comp:
L = comp("Comp 1").layer("Glass S01");
Everything is working fine except for one thing, my ease animation!, i tried to replace the linear with ease, but this gave me the normal easy ease we do using F9, i want to preserve my ease animation i did in the graph editor! is there a way to control my In and Out animation with markers while preserving my ease curves?
Bilal
Cassius Marques
Re: easy ease PROBLEM with Linear/ease()
on Feb 22, 2016 at 12:02:09 pm
I believe the interpolation will then be controlled by the expression and not the influence of the keyframe itself. So, no.
Cassius Marques
http://www.zapfilmes.com
Bilal Alsurri
on Feb 22, 2016 at 12:32:15 pm
Thanks a lot Cassius, but i still think that there is a workaround for it, i tried using valuAtTime instead of ease(t,tmim,tmax,v1,v2) and almost got there but this method shifts all the keyframes which miss the animation!
I also found a way that controls time remapping keyframes with markers on the parent comp, but in my case and because i have video in the nested comp this will cause the video to be faster or slower!
