3d layer looks transparent
phillip nugent
on Feb 18, 2016 at 8:52:01 pm
Hi everyone I need some help, I've turned on the 3d layer on a pre comp full of small 2d circles but out of nowhere they became transparent and started to flicker when they started to move. my opacity is set to 100% and they turn back to normal when the 3d layer is turned off. They are not 3d they just need to move in 3d space. any ideas?
Kalle Kannisto
Re: 3d layer looks transparent
on Feb 19, 2016 at 8:34:02 am
Just how small are the circles?
3D layers are a bit "softer" than 2D layers, which may cause small items to appear semitransparent due to antialiasing. Also, horizontal and vertical patterns made of small dots (in straigth lines) as well as thin lines are the prime candidates for flicker and moire patterns.
Rotating the pattern will help, if that is possible. If not, I'd suggest rendering it out at double the size of the final and shrinking it in post.
Michael Szalapski
on Feb 19, 2016 at 2:26:15 pm
Also, make sure your circles aren't in the same place in 3d space as something else.
- The Great Szalam
phillip nugent
on Feb 19, 2016 at 4:25:08 pm
Here is the image. the plan is to have the map and the circles fall forward. This is what it looks like when the 3d layer is turned on. I've been playing around with the material options to see if i can get it to work but most changes make it worse.
Kalle Kannisto
on Feb 19, 2016 at 4:50:18 pm
Is that map a 2D or 3D layer? If the map is 3D, it could be in front (regardless of layer order).
