Color controller overide
Davor Kampel
on Feb 13, 2016 at 6:53:14 pm
Hi all! I set up a color controller where I control all my colors, but I have a problem. For example, I want all the elements that were blue, and connected to the same color controller, to stay blue, except for one element. I tried changing the color directly on that element but it doesn't work that way, and the solution can't involve disconnecting that element from the controller. So I need a way to override the color controller. Any suggestions?
Cheers!
Chris Wright
Re: Color controller overide
on Feb 13, 2016 at 7:00:13 pm
can you put a control on the controller and keyframe it?
Kalle Kannisto
on Feb 14, 2016 at 9:52:11 am
If you are using the Fill effect for the color, you could add a checkbox control and link the effect opacity to it (under "Compositing options" of the effect).
