After Effects Scripting - Encrypt a Script
Mike Sevigny
on Feb 13, 2016 at 4:03:21 am
Is there any way to share a script with clients without them seeing the actual script? encryption?
Dave LaRonde
Re: After Effects Scripting - Encrypt a Script
on Feb 13, 2016 at 6:02:35 am
Poke out their eyes. That's about it. OR... don't give clients AE project files. They should pay you for the work you do in your delivered media files. They shouldn't steal from you by possessing the work you did in the form of your project file.
You start handing clients project files, you start shooting yourself in the foot. Or if there's no way around it, they should pay a premium for project files. Hell, it's YOUR work. Not theirs.
Dave LaRonde
Promotion Producer
Chris Wright
on Feb 13, 2016 at 2:57:39 pm
The file is in ".jsxbin" format. This is an Adobe ExtendScript protected code format, it is not human readable. It is meant to protect the source code.
http://www.adobe.com/devnet/scripting/estk.html
http://www.indiscripts.com/post/2015/12/jsxblind-first-jsxbin-obfuscator-fo...
http://www.scip.ch/en/?labs.20140515
Mike Sevigny
on Feb 13, 2016 at 5:44:04 pm
Thanks guys,
Great points Dave. They are purchasing 'the process' but I would like to avoid them updating it themselves by taking the code elsewhere. If the code is hidden and the process changes it would make sense for them to come back to us for the update.
Chris, that's what I was looking for. I'll be reading through those links thoroughly. Thank you.
Mike Sevigny
Walter Soyka
on Feb 13, 2016 at 5:56:53 pm
In ExtendScript, File > Export as binary.
Walter Soyka
Dave LaRonde
on Feb 13, 2016 at 7:28:30 pm
I obviously have never had a need to use Extendscript. Does it work on the entire project file, or does it affect only those portions the user chooses?
Dave LaRonde
Promotion Producer
Walter Soyka
on Feb 13, 2016 at 7:38:24 pm
This is for the script only, not the AEP project file. It will let the client run the script, but not see or modify its source code.
Walter Soyka
