Removing black bars on TOP and BOTTOM
Danny Paz
on Feb 6, 2016 at 2:01:19 am
Hey, so I'm working on a project where I rotate a clip and use motion tile on it as well. Though I have this issue that the black bars on top and bottom of the clip make it so I can't see only the clip inside of the black bars. I also tried masking over it, but as I rotated to see the motion tile, I saw a huge gap until I saw the motion tile itself. Basically I also can't see the motion tile because of the bars as well. I try cropping it, but the bars are still there. I just don't know a way to actually remove or delete something of a clip. Please help
Tero Ahlfors
Re: Removing black bars on TOP and BOTTOM
on Feb 6, 2016 at 8:19:15 am
You probably need to scale the clip up during the rotation so the edges aren't visible when you rotate it.
Jon Simpson
on Feb 7, 2016 at 3:16:51 pm
It is hard to understand what you are describing. Can you render it out and provide a link so we can see what you are talking about?
Pavan Gulati
on Feb 10, 2017 at 1:19:15 am
Hi Danny,
Did you ever get this resolved. You were experiencing the exact problem that I am having. I am getting the huge black gaps between the tiles with the video clips. When I try the same effect with images, I don't have the problem.
Roei Tzoref
on Feb 10, 2017 at 4:03:47 pm
1. scale the video a tiny bit until it's covering all the frame completely
2. precomp the footage -> move all attributes
3. now use the motion tile effect
you could also
1. precomp the footage - leave all attributes
2. activate the collapse switch
3. now you can scale the layer a bit and the gap will go away
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Pavan Gulati
on May 26, 2017 at 4:30:10 pm
@Roei... I never thanked you for your post. Thank you!!
