duplication of rotation
Dylan Vander Velde
on Feb 5, 2016 at 3:11:02 pm
If i have a layer, it 3d and i rotate it. If i want to apply the same rotation to the next layer, how would i do that, whats the best way
Dave LaRonde
Re: duplication of rotation
on Feb 5, 2016 at 6:06:21 pm
Copy & paste the rotation property.
Dave LaRonde
Promotion Producer
Dylan Vander Velde
on Feb 5, 2016 at 6:39:49 pm
Thank you for that. And thank you for the hundreds of other answers you have provided to my questions via other peoples posts i have found while searching AE questions :)
Walter Soyka
on Feb 5, 2016 at 7:02:08 pm
Another option: use property links. Instead of copying and pasting the rotation property itself, select the Rotation property, then use Edit > Copy with Property Links.
Now, when you paste, Ae will paste an expression onto the second layer(s) that links back to the values of the first one. That means that if you want to change the animation, you only have to change it once, on the first layer, and the second layer(s) will automatically update.
See here for more:
http://blogs.adobe.com/aftereffects/2015/08/favorite-features-in-cc-version...
Walter Soyka
