Warp Stabilizer VFX
Alex Pop
Warp Stabilizer VFX
on Jan 28, 2016 at 3:24:18 pm
Hi all,
So I have been through every VFX tutorial/post I've been able to find, but I think that because I'm trying to stabilize action footage it's a little more complex of a process it's been difficult to come across exactly the settings I need...I have several clips like the following I need to stabilize:
https://vimeo.com/153375668
I have deleted tracking points around only the skier, and also everything but the skier--but AE does not appear to actually be helped by the use of the track points on this clip--in fact once I deleted it seemed like there was no stabilization at all? Which left me with the standard subspace/perspective/scale crop presets, none of which provided a useable result with default settings.
I guess the solution here is to shoot with a stabilizer rig in the first place, but for those of us who don't have access is there a workable Warp Stabilizer solution? For this specific subject is there a tracking point delete solution that should work?
Chris Evans
Re: Warp Stabilizer VFX
on Jan 28, 2016 at 3:26:07 pm
Video is private and needs a password.
Michael Szalapski
on Jan 28, 2016 at 5:31:56 pm
Without seeing the video, I would recommend masking out everything that's moving (the skier, for example), precomp it (moving everything into the precomp), and then trying the stabilizer on the precomp.
- The Great Szalam
Tudor "Ted" Jelescu
on Jan 29, 2016 at 8:57:02 am
Before going into masking and deleting track points, I would recommend trying out the Warp Stabilizer in Premiere Pro - I got great results with minor tweaking on the settings.
Tudor "Ted" Jelescu
Senior VFX Artist
Alex Pop
on Feb 5, 2016 at 1:10:16 am
Bumping for password unlock on the video...minor tweaks to default warp settings didn't work--I always had weird artifacts etc no matter which setting I went with (usually stick with position/scale/rotation). Other thoughts on track point deletion?
Alex Pop
on Feb 16, 2016 at 10:15:11 pm
Bump again for any elaboration on track points as they apply here
