Weird 'tv static' glitch out of encoder
Dylan Mercer
on Jan 28, 2016 at 7:17:33 am
Hi, I need some ideas.
Everything I put into Media encoder keeps coming out with this angled lines accross half the frames.
I am working at quite a high resolution (1800x1717) but my 18 second animation is not very intensive.
when I send my renders to the Media Encoder Queue, I use H.264, and use the 'match source, high bitrate' preset.
all my renders from this and other after effects projects returns the same glitchy output.
here is a still from one of the renders.
-heres a link in case the embeded image doesn't work:
Dave LaRonde
Re: Weird 'tv static' glitch out of encoder
on Jan 28, 2016 at 3:24:23 pm
The first red flag is the dimensions of the render. H.264 only works with standardized dimensions.
Is there an overwhelming reason you need the ones you'using?
Dave LaRonde
Promotion Producer
Dylan Mercer
on Jan 28, 2016 at 10:19:05 pm
[Dave LaRonde] "H.264 only works with standardized dimensions."
Thanks for your response Dave. That could be a part of it, but I ran the same render through encoder on my workmates' PC (I run a Macbook Pro) And it worked fine with those dimensions
Chris Evans
on Jan 28, 2016 at 3:25:03 pm
Did you try rendering out from AE as a high quality codec, then transcoding to h.264 in encoder?
Dylan Mercer
on Jan 28, 2016 at 10:20:22 pm
[Chris Evans] "Did you try rendering out from AE as a high quality codec, then transcoding to h.264 in encoder?"
Yep I tried that. It still returned the exact same glitch!
Dylan Mercer
on Jan 28, 2016 at 10:39:43 pm
-Actually this DID work, sorry. the glitch is only hapenning for renders sent from Ae CC 2015 to Media Encoder CC 2015
Chris Evans
on Jan 29, 2016 at 4:08:48 pm
Tis an odd glitch and I don't think it should happen, but rendering high quality from AE is the general workflow most people work in anyway.
