Pickwhip path
Ahmed Ashraf
Pickwhip path
on Jan 26, 2016 at 7:40:53 pm
Hello community,
When i pickwhip Source text in Comp. to another Source text in this Comp. (Composition on this photo)
I get: Function folder is undefined expression disabled.
Any help?
Dave LaRonde
Re: Pickwhip path
on Jan 26, 2016 at 8:57:55 pm
You have to pickwhip to the identical property. Are you doing this? And even more fundamentally, are you creating an expression to be able to use the pickwhip? Or are you trying to parent two layers together?
Not sure exactly what you're doing........
Dave LaRonde
Promotion Producer
Ahmed Ashraf
Re: Pickwhip path
on Jan 26, 2016 at 11:33:42 pm
http://im2.ezgif.com/tmp/ezgif-917718629.gif
Dave LaRonde
Re: Pickwhip path
on Jan 27, 2016 at 12:06:00 am
There's no keyframe on the text layer to which you are pick-whipping. AE thinks you still may change the text.
Dave LaRonde
Promotion Producer
Ahmed Ashraf
Re: Pickwhip path
on Jan 27, 2016 at 12:24:05 am
Yea i make it to change the both texts from one layer, when i do this pickwhip i get this error.
Dave LaRonde
Re: Pickwhip path
on Jan 27, 2016 at 12:31:41 am
There's a good chance the syntax is wrong if this master layer is in a different comp.
Dave LaRonde
Promotion Producer
Walter Soyka
Re: Pickwhip path
on Jan 27, 2016 at 11:27:04 am
Pickwhipping should give you an expression like this:
comp("01 Top Title").layer("Full CONTROLLER 2").text.sourceText
If that expression is giving you an error, I would first ask if you have more than one comp named "01 Top Title" in your project.
Walter Soyka
