Moving an object in a motion tracked scene
martin watego
on Jan 24, 2016 at 3:10:52 pm
Hi everyone, I'm new to this forum so thank you for taking the time to help me out. I have been reading previous threads but can't find what I'm after.
I have a scene in Cs6 of a table that I have motion tracked and parented an image of a horse to the tracked data. When the camera moves around it sticks perfectly.
But if I want the horse to run in a straight line to the other end of the table while the camera is moving around the motion tracked scene, how do I make this happen.
I set key frames for the position of the horse once it was 3d and stuck to the image but I can't get him to run in a straight line down the table, As the camera moves the horse moves far from the path I want him to go in looking unrealistic.
So sorry this was long to explain.
Any help would be greatly appreciated. I have been reading forums and looking at youtube for days but can't find anything to help me
Thanks again
Dave LaRonde
Re: Moving an object in a motion tracked scene
on Jan 25, 2016 at 6:07:02 am
If Iunderstand you correctty, you won'have a lot of luck. It sounds likethis is a 2D image. As soon as you move the camera in. 3D space, it will stick out like a sore thumb.
You'd need to build a 3D horse, animate it and do the camera move in a 3D application, not AE..
Dave LaRonde
Promotion Producer
martin watego
on Jan 25, 2016 at 11:52:15 am
Ah thanks so much Dave makes perfect sense. It does stick out like a sore thumb and that's being nice :)
I really appreciate the help and advice. I won't waste any more time on this idea and will try and come up with an alternative.
Thanks again
