Contour map?
David Jones
Contour map?
on Jan 22, 2016 at 10:02:27 pm
Hi, Please can anyone give advice on how to achieve the following: A bit like displacement map but imagine the alpha or luminosity of the map is just used to control the zoom and warp of something that moves over it. So like you looked down on a 2D map in front of you and a ball rolled over it, it would get larger and smaller like it was rolling over the contours of real mountains. Sorry this may be a common issue with an existing plugin or not possible i just dont know what to search for. Even better if it can enlarge / shrink parts of the object differently so it gets warped with the 2D map.
Thanks for reading
© 2018 All Rights Reserved
