Line of shapes, changing to another shape at a point long a line - HOW TO?
Cordelia Brown
on Jan 22, 2016 at 3:20:41 am
Hi there,
Does anyone have any ideas on how to do this? With or without script/plugins.
See attached picture...there are lines of different shapes/colours (some little triangles, circle, squares etc) coming from left of screen (off a train/tube map style arrangement) they then need to change into the purple rectangle lines when they hit a point on screen. The arrow shape and colour change is not such a problem for me, I can just mask that shape/colour in. The main problem I'm having is how to get the shapes to change progressively at a point rather than all at the same time.
Any suggestions would be greatly appreciated.
Cassius Marques
Re: Line of shapes, changing to another shape at a point long a line - HOW TO?
on Jan 22, 2016 at 12:34:13 pm
How are the lines coming in? For example the green dots, are you revealing them with a stroke wipe or do they scale up? Maybe they're already on the screen and you're moving the camera?
These are important things to consider.
Cassius Marques
http://www.zapfilmes.com
Cordelia Brown
on Jan 25, 2016 at 2:49:27 am
So I ended up figuring it out myself for anyone who is interested...
The lines were coming in from the left of screen.
I made a shape for each line (eg orange triangle).
Then I pasted the path that I wanted them to travel along onto their position value (making sure their anchor point was centered).
Then right click > trransform > auto-orient > orient to path
This key frames the shape moving along the path.
Then apply Echo effect (Time>echo) and adjust the setting to suit desired spacing and amount of repetitions needed.
Done!
Cordelia Brown
on Jan 25, 2016 at 2:51:50 am
Oh and then when you want the shape in the line to change (ie orange trianlgle to purple rectanlge) just do this as you normally would with a shape (keyframe change shape path and fill colour) at the desired time. Echo will change the shapes progressively down the line.
