shy switch not working
Bruce Gaber
on Jan 20, 2016 at 2:26:12 pm
Is it just me, or doesn't the Shy switch work correctly in the current version (13.6.16). Shy itself works if I use the timeline pull-down menu, it's just the switch that fails to do anything. I've read the earlier threads on this, and I have not added any offending plug-ins that might affect layer behavior.
Bruce
Photographer / Motion Graphics Artist
Vision Rising
vimeo.com/BodhiBruce
visionrising.com
Dance Without Reason
Tero Ahlfors
Re: shy switch not working
on Jan 20, 2016 at 3:29:52 pm
Are you talking about layer specific shy switches or the comp master shy switch?
Bruce Gaber
on Jan 20, 2016 at 8:06:41 pm
The switches turn on and off on the layers (nothing is shied of course). It is the switch at the top of the timeline that is supposed to toggle the shying on and off that does not seem to fnction
Vision Rising
visionrising.com
Richie Schut
on Nov 2, 2016 at 6:31:40 am
I am having the same problem in version 13.8.1.38. Did you ever find a fix?
