Do most AE animators continuously rasterize?
Samuel McClure
on Jan 16, 2016 at 5:25:21 am
I've been watching a lot of tutorials where animators use the puppet pin tool to bend their characters. This doesn't work if you turn on continuously rasterize, so I haven't seen anyone use that setting. Is this good practice, or are there better ways to bend an image that will allow you to continuously rasterize vectors?
Dave LaRonde
Re: Do most AE animators continuously rasterize?
on Jan 16, 2016 at 4:59:44 pm
The Puppet Tool can be the. ONLY thing applied to a layer. If you need to change the size of the layer, do it in a nested comp.
Dave LaRonde
Promotion Producer
Samuel McClure
on Jan 17, 2016 at 3:40:02 am
I've got a 2d character who is looking up. Her head rotates upward, and I've got her hair parented to her head. I would like to be able to jiggle her hair a little bit with the puppet pin tool, but the only way I'm able to is if I keep 'continuously rasterize "off, even though there isn't anything else applied to the hair layer.
Dave LaRonde
on Jan 17, 2016 at 4:12:10 am
..including any transform property modifications... scale, position, rotation, etc?
Dave LaRonde
Promotion Producer
Samuel McClure
on Jan 17, 2016 at 5:05:30 am
Yep. It's just a layer parented to the head, with only the puppet pin effect. No transformations, and no camera effects are used either. Works fine until I turn on 'continuously rasterize'.
Dave LaRonde
on Jan 18, 2016 at 11:52:22 pm
Sorry, I must have mislead you. You can't do continuously rasterize and use the puppet tool. Using continuously rasterize counts as applying something to a layer in my book, but perhaps not yours.
Dave LaRonde
Promotion Producer
Samuel McClure
on Jan 19, 2016 at 8:55:14 pm
Ok, thank you. Sorry for the confusion, still getting the hang of AE.
