After Effects, Proxies, DNG Sequence, Adobe Camera Raw
Gabriel Catalin
on Jan 15, 2016 at 7:59:31 pm
Hi!
I have a little problem. I imported some DNG Sequences to AE and edited in Camera Raw, after that I made proxies of all the files and tried to edit again the Camera Raw, I went to Interpret Footage > Main > More Options, Camera Raw was opening, I made the modifications, but after apply, nothing happens, no change in the composition... I turned off / on the proxies, nothing, still no change. What can I do to still use Camera Raw after making the proxies?
Thanks in advance!
Gabriel Catalin
Re: After Effects, Proxies, DNG Sequence, Adobe Camera Raw
on Jan 17, 2016 at 12:41:48 pm
nobody had this problem before? :(
Gabriel Catalin
on Jan 21, 2016 at 1:28:22 pm
Another problem is that even if I remove the proxy and replace the footage, ACR will not work correctly, I will have some flickering if I change the exposure...
