can't see footage
Yonatan Lehman
can't see footage
on Jan 14, 2016 at 10:27:19 pm
I must be doing something stupid...newbie....
I'm trying to output some still frames footage - starting from 55 seconds, for a duration of 1
I input the footage (a VOB file renamed to .mpg), drag it down to the timeline - but I cant see anything in the composition window.
I think that this may be because I messed up the composition settings - but it could be for something else I did.
What is the composition start time ? Relative to what ?
specifically in my case - if I want to output 25 frames starting at 55 seconds into the footage (which is placed at the start of the composition)
What should teh composition start time br ? At what timeline time will I see the first frame I want to output ?
I'm using AE 7.0
Michael Szalapski
Re: can't see footage
on Jan 14, 2016 at 10:54:01 pm
AE versions that old weren't terribly good with interframe compressions like MPEG.
But even if it were good, what you're asking to do would be much easier to do in a video editing application like Premiere. AE is NOT for editing video.
- The Great Szalam
Dave LaRonde
on Jan 15, 2016 at 12:08:12 am
I'm with Michael -- DO NOT use mpeg2 footage ripped from a DVD in AE. It just won't work right. Go get MPEG Streamclip to transcode it to something like a QT in the Photo JPEG codec.
As for the rest, just trim up the clip to the number of frames you want and render an image sequence.
Dave LaRonde
Promotion Producer
Dave LaRonde
on Jan 15, 2016 at 12:29:15 am
I forgot to add this -- MPEG Streamclip is free.
Dave LaRonde
Promotion Producer
Yonatan Lehman
on Jan 17, 2016 at 7:45:37 pm
OK Thanks
