how to make a dice only with lines (no fill) that doesn't look transparent
marina martins
on Jan 12, 2016 at 4:20:33 pm
Hello everyone,
I would like to make a dice that has no fill, only lines. the problem is when a do that, it looks like the dice is transparent, but I don't want to see the lines that are behind.
I want to animate the dice and still be able to see just what's in front, like it would be if the side had a fill color.
Is it doable? Maybe there's a script to help me?
Thank you!!!
Kevin Camp
Re: how to make a dice only with lines (no fill) that doesn't look transparent
on Jan 13, 2016 at 12:52:37 am
would need to know more about how you have your dice constructed, but dan ebberts' 'layer invisible when facing away from camera' expression might help.
you'll find it here (with a good description of how it works):
http://motionscript.com/design-guide/invisible-facing-away.html
it will only work if you are using 3d layers to create your dice 'outlines'.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Kalle Kannisto
on Jan 13, 2016 at 9:44:50 am
How about filling the sides with black or green and keying them out?
marina martins
on Jan 15, 2016 at 3:04:23 pm
Thank you!!!
That is exactly what I needed!
Tudor "Ted" Jelescu
on Jan 13, 2016 at 10:36:18 am
You can try playing with find edges and see if that's what you're after
Tudor "Ted" Jelescu
Senior VFX Artist
