Black Composition Preview
Yvanne Rabe
on Jan 9, 2016 at 1:55:56 pm
I can't seem to see anything in my composition preview panel. :(
I'm thinking that this is a graphics driver problem. Thank you :)
Dave LaRonde
Re: Black Composition Preview
on Jan 10, 2016 at 2:11:15 am
You see the layer quality switch? The one with the diagonal dotted line? Click on it and set it to high quality - a solid line going in the opposite diagonal direction. Then see what happens.
Dave LaRonde
Promotion Producer
Yvanne Rabe
on Jan 10, 2016 at 4:26:19 am
Thank you for the answer but unfortunately that did not work. Also, even if I zoom-in in the composition, the black area is constant and does not move.
Yvanne Rabe
on Jan 10, 2016 at 9:07:38 am
I solved it! But temporarily. It was indeed with my graphics drive, I disabled my Nvidia 970M but kept my Intel HD Graphics 530. And it worked. Although this would be troublesome since should I disable my nvidia driver everytime I will use After Effects? Does anybody know what to do about this?
Cheers!
