Can you use more than one write-on for one layer
Dingdang Ding
on Jan 8, 2016 at 9:53:26 pm
Hi
I have a big graphic in TIFF format, used many write-on effects, when I changed all write-ons to 'Reaveal image', it becomes entirely black, nothing gets revealed.
Can you use multiple write-on effects on one layer in AE.
Dave LaRonde
Re: Can you use more than one write-on for one layer
on Jan 8, 2016 at 11:48:53 pm
The last time I used Write-On to animate a signature -- a few AE versions ago -- I saw that when I tried multiple instances of the effect on the same layer, I could see the initial pen points just sitting there before they animated. I Put each instance on its own layer.
Maybe it has changed. I'm not sure.
Dave LaRonde
Promotion Producer
Dingdang Ding
on Jan 10, 2016 at 5:11:11 am
I solved that by making the brush size to 0 until when you want it show up. Still besides this, did it work at all? Multi on one layer?
Dave LaRonde
on Jan 10, 2016 at 11:24:37 pm
If you can get brush size to zero. -- which I could not do before -- I'd give it a shot. You'll have to do that for each instance of the effect.
Dave LaRonde
Promotion Producer
