CC Ball Action disable self shadow
Artsiom Chikov
on Jan 6, 2016 at 7:56:32 pm
Hello!
The whole day I'm trying to turn off the self shadow effect from CC Ball Action
I tried to apply the Shadow/Highlight effect, change blending mode from normal to screen.
I'm just want to get a solid matte color.
I'm confused :(
Please help
Dave LaRonde
Re: CC Ball Action disable self shadow
on Jan 7, 2016 at 12:21:22 am
CC Ball Action defaults to simple colored circles. Which AE version are you using, and on what operating system?
Dave LaRonde
Promotion Producer
Kevin Camp
on Jan 7, 2016 at 12:53:07 am
this may work for you...
try adding a gray solid (128 for all the rgb values, if working b-bit) and hide it.
then add these effects to your ball-action layer (after ball action):
  • channel combiner
  • set channels
  • channel combiner
things will look really crazy, so first set the 'from' property of the second channel combiner to 'rgb to hls' to get them looking back to normal.
now in the set channels effect, set the 'source layer 2' property to be the gray solid.
it should flatten out the luminance of the balls, but leave the colors. changing the luminance of the gray solid (in the solid settings) to make it darker or lighter can help to fine tune the values of the colors if needed.
you could also try just using the color balance (hls) effect, increase lightness and saturation and see if that can get you close, pretty simple, but i don;t think it will be as successful.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Artsiom Chikov
on Jan 7, 2016 at 10:06:12 am
That's what I was looking for.
Thank you!
David Cabestany
on Oct 20, 2017 at 3:46:39 pm
Quick comment,
it's actually from HLS to RGB on the second Channel combiner, not RGB to HLS.
Best,
D.
