Adobe Media Encoder has encountered an error. [..\..\Src\ExporterParam. cpp-509]
Lyubov Leahu
on Jan 6, 2016 at 12:37:29 pm
We try to render 400+ AEP. I've got a watch folder set up to export AE projects with next settings: H.264 (1280x720, FPS 25, VBR 2 pass, 1.5 target 2 max; AAC 48000Hz, 320 kbps). The error appeared within the first 30 projects:
we had 400+ videos going overnight, it might only do so many of them before the error arised. When I clicked to continue render proccess (at that point where it stopped) AME started doing that but without images and video files (it didn't find the path to the project files).
Can anybody help with this, please?
Nvidia GeForce GTX Titan X, 4 Cores, 8 Threads.
Adobe Media Enchoder CC 2015.0.1
Dave LaRonde
Re: Adobe Media Encoder has encountered an error. [..\..\Src\ExporterParam. cpp-509]
on Jan 6, 2016 at 3:22:11 pm
I recommend that you use AE CC 2014 for these renders... and, of course, AME 2014.
AE CC 2015 has render issues. AE CC2014 can read the 2015 project files and it does not have such render issues.
Dave LaRonde
Promotion Producer
J. Mechanicus
on Jan 25, 2017 at 1:14:38 pm
Had the same problem.
Seems the prefs are corrupted. Go to the prefs rename the directory.
Open media encoder and copy presets from the old to the new preferences.
