Change default naming Precompose after effects
Dasher Mokum
on Jan 5, 2016 at 3:10:47 pm
Hello,
Is there a way to change the default name that AE generates when you precomp some layers.Defaults name is Pre-comp 1.
I like to change it to "Pre_"
Cheers
Thierry
Dave LaRonde
Re: Change default naming Precompose after effects
on Jan 5, 2016 at 3:22:13 pm
You can change comp names in their composition settings. Very easy to do.
Dave LaRonde
Promotion Producer
Dasher Mokum
on Jan 5, 2016 at 3:25:36 pm
Thanks for the quick response. That I knew... but i don't feel like change the name to the way i like to name them.
The default is always Pre-comp 1. I like to change that to my custom default every time i precompose layers.
Dave LaRonde
on Jan 5, 2016 at 6:54:50 pm
I think you should look in AE Preferences to change it. If it can be changed at all, it would be there. When you open AE Preferences, hold down the Shift key to open ALL the preferences so you can do a thorough search.
Dave LaRonde
Promotion Producer
