Trying to Render Super Wide 16768x48 Pixels, Coming out Black.
Andrew Persing
on Jan 5, 2016 at 12:37:11 am
So i'm trying to render this super wide video and convert to AVI, I am rendering Photo.jpg and coming out black.
I'm able to render a JPG sequence that is 16768 wide and 48 pixels tall that works but how can I convert this image sequence to AVI?
Please help, Running a mac with After Effects 2015.0.1
Thank You!
Andy
Tero Ahlfors
Re: Trying to Render Super Wide 16768x48 Pixels, Coming out Black.
on Jan 5, 2016 at 10:41:35 am
What are you trying to do with this resolution?
Walter Soyka
on Jan 5, 2016 at 11:10:48 am
It's almost certainly a stadium fascia board.
Andrew, can you explain step-by-step what and how you are outputting, what you're using to transcode, and where the process fails?
Walter Soyka
Dave LaRonde
on Jan 5, 2016 at 3:29:13 pm
In addition to Walter's questions I ask...
Do you have concrete delivery specifications?
How will the completed file be played back?
I wonder if the client needs not one extremely wide animation, but several narrower animations to be played back simultaneously.
Dave LaRonde
Promotion Producer
Andrew Persing
on Jan 8, 2016 at 12:19:53 am
Hey everyone, thanks for the quick responds. I will be getting more details soon about what needs to be delivered and yes it is for a stadium fascia board.
Andy
Andrew Persing
on Jan 13, 2016 at 12:35:09 am
Hello Everyone,
So I have gotten some answers and I do in fact have to create a final render this being an uncompressed AVI at 16768 pixels wide and 48 pixels tall at 30FPS.
In responds to Walter it is a stadium Fascia board. Also I am outputting .JPG image sequence out of After Effects on a Mac and trying to create the AVI file using MPEG Streamclip.
In responds to David these are the concrete specs as far as delivery of the video and not sure exactly how it is being played back, with what system but it is for a stadium Fascia board. The client was asked if we could use multiple animations and they said no just the wide super wide one.
What is the best way to create an uncompressed AVI file on a mac from a .JPG image sequence?
Or what is a better method to get from After Effects to my file delivery?
Thank You very very much for any help getting this project done!
Andy
Tero Ahlfors
on Jan 13, 2016 at 5:23:36 am
AVI is really old and I'm not sure that resolution is even possible in that format.
Walter Soyka
on Jan 13, 2016 at 12:02:32 pm
[Tero Ahlfors] "AVI is really old and I'm not sure that resolution is even possible in that format."
The specs make sense. Many of these arena ribbon LEDs run systems that use uncompressed AVI at the native resolution of the whole array. 16768x48 is absolutely doable in AVI.
Ae on a PC can output directly to AVI with these specs. Maybe try a demo of Episode, Squeeze, or some other compression program?
Walter Soyka
Tero Ahlfors
on Jan 13, 2016 at 6:06:56 pm
[Walter Soyka] "16768x48 is absolutely doable in AVI. "
That resolution compeletely kills AME when I tried it. I can pick the resolution but the program crashes instantly when I try to render it.
Walter Soyka
on Jan 13, 2016 at 6:16:02 pm
That's an AME bug, then. Try it directly from Ae.
Walter Soyka
Andrew Persing
on Jan 13, 2016 at 7:02:16 pm
I'll probably try and use the demo of one of those compression programs.
Worse comes to worse they will get a static graphic in place of a quickly animated in and out graphic.
Thanks for the help Walter!
Tero Ahlfors
on Jan 14, 2016 at 11:47:35 am
[Walter Soyka] "Episode"
Doesn't work. Too big value for the codec.
