Extending box proportionaly with its keyframes
Goc Cvet
on Jan 4, 2016 at 7:41:46 pm
I'm pretty new to AE so I will probably loose myself trying to explain my problem because I don't know all your terms.
I got this animation of a box extending its width. In order to accelerate it has key-frames. I learned how to extend the key-frames proportionally but the problem is the width. If I enter the width of the last key-frame only, the width to the other key-frames is the same as before. So instead of getting the same animation but getting bigger width box through the whole sequence, I get the full width only from the pre-last and the last frame.
Does this explain my problem? :D
skullmonkey
Michael Szalapski
Re: Extending box proportionaly with its keyframes
on Jan 4, 2016 at 8:26:46 pm
Park the current time indicator over a keyframe. Select all of the keyframes. Scrub the value. All of the keyframes will get that value change added.
- The Great Szalam
