Change frame rate witout dublicate frames?
Julius Valentinas
on Jan 4, 2016 at 3:19:55 am
Helo, in after effects
1. I create a comp with 30fps,
2. then I import a file sequence at true 30fps as 24fps using interpret footage -> main -> assume this frame rate
This makes what I want, except it makes duplicate frames. Any way around it?
Dave LaRonde
Re: Change frame rate witout dublicate frames?
on Jan 4, 2016 at 3:48:56 am
No. It is not possible. You can illustrate for yourself what is happening.
Get two one-meter-long pieces of paper, a ruler and a pencil. Mark 30 equally-spaced sections on one piece of paper. Mark 24 equally-spaced sections on the other piece of paper. Line them up. See how a couple of the 1/24 sections span two of the 1/30 sections?
That's what is happening in your comp.
NOW -- here is the real question: what are you trying to accomplish by mixing the frame rates? Mixing frame rates is rarely pretty.
Dave LaRonde
Promotion Producer
Kalle Kannisto
on Jan 4, 2016 at 8:52:28 am
Any reason not to make the comp itself 24 fps?
Dividing (or multiplying) the frame rate with an integer, making it 15 or 10 fps, is a better option visually. You could try using pixel motion frame blend to attempt to create in-between frames, but that is rarely flawless.
