Candle Fire - Motion Tracker problem
Jakub Frišo
on Dec 29, 2015 at 10:48:07 am
Hello guys I need your help with one specific shot in my movie ... In the shot is moving candle that we recorded not lit up so we can add fire, smoke and wick of a candle in postproduction. But I came to a problem in After Effects, the motion tracker doesnt track the movement of a candle correctly and the mask (fire, smoke and wick of a candle) that I parented to the null object later on wiggles around pretty visibly. Is there any way that I can track the movement better? I tried many methods but they didnt worked ...
link to problematic footage
https://www.dropbox.com/s/87l9jhrm2s...0shot.mp4?dl=0
Kalle Kannisto
Re: Candle Fire - Motion Tracker problem
on Dec 29, 2015 at 1:16:39 pm
Your link doesn't work.
What methods have you tried already?
Ivan Myles
on Dec 29, 2015 at 2:49:08 pm
• You might need to use several tracking points in series to get through the clip.
• If individual points don't work, try tracking the entire candle.
• If the image is low contrast, make another composition with the clip and blow out the levels to create high contrast between the candle and the surrounding area. Insert the comp with the modified levels into the main comp, track the high contrast candle, apply the motion data to the original clip, and hide the high contrast comp.
Jakub Frišo
on Dec 31, 2015 at 12:47:00 pm
https://www.dropbox.com/s/87l9jhrm2si7xlw/Candle%20Fire%20shot.mp4?dl=0
sending the link again
Ivan Myles
on Dec 31, 2015 at 2:50:08 pm
What part of the clip do you find to be problematic? The tracking looks OK. The flame is a little stiff near the end, but I'm not sure a casual observer would notice.
Kalle Kannisto
on Dec 31, 2015 at 4:07:30 pm
I agree. I didn't notice any tracking problems. The air would have to be extremely still for the flame to be that undisturbed, but even that fits the mood of the shot fine in my opinion.
Jakub Frišo
on Jan 1, 2016 at 11:02:40 pm
I think when you watch the shoot fullscreen you can spot some shaking of the flame and wick at least its pretty visible for me ...
Jakub Frišo
on Jan 4, 2016 at 9:37:36 am
So I did the tracking and I think it ended up well. But I can came to another problem ... Can you please help me by telling me how can I create (simulate) glow of the candle on the the hand and thumbs which put out the fire of candle? I did rotobrush of hand but I dont know how do I have to combine different layer blends to achieve the look ...
Please how would you approach this problem?
Link to problematic footage:
https://www.dropbox.com/s/vlw5zkgbiusmpoo/Sequence.mov?dl=0
Sending pictures of my composition and different layers i hope that will help you. If you will need any more informatiom just tell me ...
Thank you so much
Raw Comp: https://www.dropbox.com/s/t9plzdtzjb25f4t/Raw%20comp.jpg?dl=0
Comp with added layers: https://www.dropbox.com/s/2jxrn6b4j4mvr7p/Edited%20comp.jpg?dl=0
Different layers: https://www.dropbox.com/s/ub4cwvph8zvb5zi/Layers.jpg?dl=0
Hand that needs to be rotobrushed (i didnt add roto yet because i want to know how will I make hand glow with mask):
https://www.dropbox.com/s/xsfe9rmtiebitle/Rotobrush.jpg?dl=0
