From Black & White to Color audio react
Major Attila
on Dec 19, 2015 at 8:58:38 pm
Hello guys. I'd like to make my background react to audio so when the audio is lower then the background turns black & white but when audio is higher the background turns to its normal colors. Right now I am using the Black & White effects from colors and presets, the effect has opacity so I guess a simple expression would do the job. I tried using this expression :
x=thisComp.layer("Sound Keys").effect("Sound Keys")("Output 1");
linear(x, 0, 100, 0, 150)
But this expression does it vice versa on how I'd like it.
Kalle Kannisto
Re: From Black & White to Color audio react
on Dec 20, 2015 at 10:35:06 am
On a quick glance, reversing the last values to something like
linear(x, 0, 100, 100, 0)
should do it.
Major Attila
on Dec 20, 2015 at 12:05:23 pm
Thanks. I had to do a little bit of tweaking but works fine !
