Masking out a seam on a back drop.
Miguel Zamora
on Dec 17, 2015 at 2:10:54 am
Hi All,
I don't know if I'm in the right forum, but I'll give it a shot. I'm editing a video of a pretzel warmer, and the Director would like to have a seam removed from the back drop. I attached a photo as reference. You can see the seam running through the middle of the frame. Any suggestions on how I can mask this out, seamlessly?
Thank you!
Kalle Kannisto
Re: Masking out a seam on a back drop.
on Dec 17, 2015 at 7:45:09 am
Should be a simple matter of duplicating the footage, masking off two pieces of the wall above with a feathered mask on the copied layer and moving it down to cover the seam. Possibly a slight curve is needed to match the luminosity.
Miguel Zamora
on Dec 17, 2015 at 7:10:29 pm
Thank you, Kalle, I will give it a shot!
