Is there a plugin in AE that does this?
Christian Vilderman
on Dec 15, 2015 at 3:11:53 pm
thanks
John Cuevas
Re: Is there a plugin in AE that does this?
on Dec 15, 2015 at 3:17:42 pm
No, you need to manually do it that. If it's something you are doing a lot. You probably could set up your video in a "Source precomp", move that precomp into new a comp(s) and do all the work for you final. Then when just drop a new video into your "Source Precomp" and render then next one.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Christian Vilderman
on Dec 15, 2015 at 3:19:47 pm
Ok. Thanks!
