"Space" Character is different than in other applications
Lennert Daniëls
on Dec 14, 2015 at 12:46:13 am
Hi folks,
So I'm working on a project in After Effects CS6 (Windows), and I'm using the Impact Label font.
As you can see, all characters are supposed to be surrounded by a box in the chosen color. The letters themselves are transparent. The "space" character should just be a box, without any transparent parts, but in After Effects, all spaces just show completely transparent.
I've checked the font in Microsoft Word, Photoshop (CS6), and even in FontCreator: the space character should definately be an opaque box.
Is After Effects replacing it by it's own version of the space character? Is there a workaround?
You can download the font here for testing. Let me now if it's the same in AE CC.
Thanks in advance!
Lennert
Dave LaRonde
Re: "Space" Character is different than in other applications
on Dec 14, 2015 at 3:55:01 am
I guess I don't understand the problem. If the text needs to be in a box , just put it in a box made out oc a solid or a shape.
Dave LaRonde
Promotion Producer
Lennert Daniëls
on Dec 14, 2015 at 9:27:34 am
That would be a cumbersome workaround for 100+ text layers...
If you take a look at the font download page, you can see this "box" is actually part of the font.
EDIT: I've tested another font with a non-blank space character: "Top Secret".
AE just uses a blank space instead of the font-specific space character. Works fine in other applications though...
Dave LaRonde
on Dec 15, 2015 at 12:39:41 am
If the typeface works in other applications, I'd suggest making the text in Photoshop.
Dave LaRonde
Promotion Producer
Cassius Marques
on Dec 15, 2015 at 10:56:07 am
have you tried imputing the character map's number of space? alt+0160 ? It is still cumbersome but at least copying and pasting is faster than manually positioning rectangles.
Cassius Marques
http://www.zapfilmes.com
Lennert Daniëls
on Dec 15, 2015 at 2:25:46 pm
Cassius: Unfortunately, the Altcode didn't work either... Same goes for copying the text from other applications.
Dave: Text needs to be editable, can't go with stills. Also way to cumbersome, considering I need 100-200 perfectly aligned text layers.
Could someone test this problem in AE CC? I'd like to know if Adobe fixed it. Some fonts to test: "Impact Label" and "Top Secret".
I'm now resorting to using a nasty combination of parenting and expressions to create shape layers around the text. A real brain challenge to set up, but sort of semi-automatic when it's finally working.
This workaround also doubles my layer count, since I need one shape layer for every text layer. I'm estimating it'll end up being about 400 layers total.
Kalle Kannisto
on Dec 15, 2015 at 2:45:27 pm
Same issue in CC2015.
A relatively lame workaround idea: Make two characters that don't have any overlapping parts (such as . and +) and use negative tracking value to place them on top of each other. Select this pair copy it and paste it wherever you need a space character.
Lennert Daniëls
on Dec 15, 2015 at 3:13:48 pm
@Kalle Kanisto: That's actually a fairly good workaround. It sparked an even easier idea given the software I have access to:
I could use my font editor to remap the space character to some character that I don't use, and perform a "find and replace all" script within After Effects.
Thanks to all! :)
Reported to Adobe, hopefully they take it seriously.
