Element 3D Text Not Moving With Camera
Harrison Bitonti
on Dec 11, 2015 at 11:13:56 pm
I've continuously had this problem in element 3D, but only on this project. I have made sure that I have created a null/camera from the tracked scene, the camera is tracked correctly, there are no frame where it cant track, the composition sizes are normal, etc. No matter what I do, whenever I try to move the text along with the camera, it stays in the same spot like there is no camera. Here's a few screenshots:
https://gyazo.com/0e2895d3deb8dceda216bf011e10ff59
https://gyazo.com/384c8abf2c10984ebb3bf9c2954cc910
Any help? I have never had this problem before, and its only on this project...
Kalle Kannisto
Re: Element 3D Text Not Moving With Camera
on Dec 12, 2015 at 6:48:06 am
The text layers itself is visible and set to continuous rasterize and lighten mode, why?
To make the text in Element, you make a text layer as a different layer from the Element layer (which would be a solid with the Element effect on it), the text layer would be hidden and selected as a custom text layer in the Element Effect Controls.
