Lens flare and radio wave effect covering each other
Tom Batt
on Dec 10, 2015 at 8:30:56 pm
I'm trying to have a lens flare streak across view with radio waves pulsing in the background, but each layer covers the other no matter which I put on top.
Do I have to add the effect to a particular type of layer?
Any help or a tutorial would be much appreciated. I'm using CS6
Michael Szalapski
Re: Lens flare and radio wave effect covering each other
on Dec 10, 2015 at 10:55:27 pm
They should both be applied to solids that are the same size as your composition. The lens flare should be applied to a black solid. The lens flare layer should be set to screen or add blending mode.
- The Great Szalam
Tom Batt
on Dec 11, 2015 at 7:30:38 am
That solved my problem, thanks so much for your help
Michael Szalapski
on Dec 11, 2015 at 2:00:53 pm
No problem!
- The Great Szalam
