Rotate in circle and maintain the alignment of an object in the circle
Rafos Sofar
on Dec 10, 2015 at 7:01:22 pm
Hello. I am new to this forum and amateur in After Effects. I would like to know how to rotate an image of gun roulette with a vinyl inside that I have made while maintaining the needle of the vinyl in the same alignment while spinning (I mean I want the needle not to spin with the gun roulette. Sorry for my English. I would be very greatful if someone could help me.
P.s Below you can see the image.
Michael Szalapski
Re: Rotate in circle and maintain the alignment of an object in the circle
on Dec 10, 2015 at 10:57:54 pm
If you want it to happen automatically, you could use expressions to tie the rotation of the record with the needle to the rotation of the gun barrel. Then simply add *-1 to the end of the expression.
- The Great Szalam
Rafos Sofar
on Dec 14, 2015 at 8:49:20 pm
Michael thank you very much for your response but I 've got some more questions on how to achieve that. Do the needle and the gun barrel have to be in separate layers (different images) or in one? Is there any video tutorial on how to do that?
Thank you in advance!
Cassius Marques
on Dec 15, 2015 at 11:08:50 am
You should watch some basic tutorials of AE. Any on them will help you understand how to do that.
Try for "rotating layers" and "masking layers" and "adding expressions".
Cassius Marques
http://www.zapfilmes.com
Kalle Kannisto
on Dec 15, 2015 at 2:54:37 pm
See Walter's "super-simple method" here:
https://forums.creativecow.net/thread/2/1041261
