Creating particle explosion
Brenden Younan
on Dec 9, 2015 at 1:03:37 pm
Hello,
I want to create a particle explosion transition similar to the video below (0:01 - 0:02).
How can I achieve this using AE CC.
Thank you.
John Cuevas
Re: Creating particle explosion
on Dec 9, 2015 at 2:53:53 pm
Shatter effect-glass settings, increase the repetitions.
Shatter is easy once you learn the mechanics behind it, but there are quite a lot of little things to know, you might want to check out a tutorial on it.
Shatter Tutorials
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Brenden Younan
on Dec 10, 2015 at 1:36:09 am
Thank you for the reply John.
I think you might be talking about a different transition from the video? because the shatter effect which I tried, doesn't match the look I'm going for
I meant this type of transition:
1.
2.
Thank you.
Daniel Waldron
on Dec 10, 2015 at 3:05:57 pm
To get the rose petals exploding out like that, you would need a plugin like Trapcode Particular or Element 3D (which is actually a pretty great particle generator). If you don't have these 3rd party plugins, you could probably use CC Particle World with a shaded sphere particle type to get a similar look.
